Gerald55's avatar
Gerald55
Switch for alternator to coach battery disconnect
I would like to be able to sometimes turn off the engine alternator charging of the house batteries on my rig. To do that, I'm thinking of putting a switch on the positive chargeline running from the alternator back to the batteries. This line is already accessible from inside since it passes through a 120A DC breaker in a cabinet in the coach.
I'm not sure what kind of switch is appropriate here. I gather that I can't just grab any SPST switch off the shelf at home depot, since these are mostly designed for typical AC voltages of 20A or lower, and I think up to 100A or so may be passing through the switch during charging, and I also understand that DC current is harder for switches to turn off, particularly for inductive loads (I don't know if the alternator/battery circuit is an inductive load, however).
Any tips on what kind of switch would work?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
