joe0508's avatar
joe0508
Tail wagging
I have a 92 p30 chassis narrow track 30 ft motorhome.It has a little bit of an oversteer problem.I think it might be contributed to a tailwagging issue.How would i know for sure before going and paying the almost 600$ price tag for one?
  • rk911 wrote:
    just curious...do you over-inflate your tires beyond what's needed to carry your load? might that be your problem or is this something that just popped up?
    Tires are inflated according to chart.Its been doing it for the 3 years that i have had it.I have done numerous things trying to improve it.Including front end parts checked, alighnment,New front tires,Steer safe stablizer.Super steer bellcrank,Adjusting front coil spring airbags back and forth,alighnment with more caster.It has improved a little but not to my satisfaction.If i wonted i could drive it with one hand but gets my wrist hurting after awhile from the constant small adjustments.I wished i could tell for sure if it is the rear wagging that was causing my issue.
  • j-d's avatar
    j-d
    Explorer II
    I know little about P30 other than what I've read.
    1. There are a lot of front end steering component upgrade parts for the P30. That indicates to me that many P30 front ends get sloppy. I CAN say from experience that a truck with worn front end, whether Bushings, Ball Joints, Tie Rods, Idler/Pitman Arms, King Pins etc. will wander all over the road. So I think it's safe to suggest being sure your front end is tight before spending $ on the rear.
    2. Henderson's LineUp is famous for their RV handling improvement skills and parts. They offer SuperSteer P30 front end parts for example. In an article on their webpage, they discuss the development of the REAR TRACK BAR. That's the part I think you're talking about for tail-wagging. Back to the article, it says one of the Hendersons was looking at a wandering P30 on their lift and noticed that there were rub marks on parts Three Inches away from the rear springs. It was that finding that contributed to the development of the Track Bar. That tells me a P30 is a good candidate for a Track Bar, just that I don't want you to work on the Rear without considering the Front.
  • just curious...do you over-inflate your tires beyond what's needed to carry your load? might that be your problem or is this something that just popped up?
Having RV issues? Connect with others who have been in your shoes.24,235 PostsLatest Activity: Apr 10, 2025
