ridemtraExplorerJul 01, 2017tandem axle equalizeranyone have an equalizer flipped over with the rear leaf spring below equalizer have both sides in the same position can this be returned to original position without total disassembly
IvylogExplorer IIIJul 01, 2017Jack on axle or end of equalizer bar that is correct and using a bar you can snap the wrong one back in place...it may go back on it's own.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
Related ContentTandem axle vs singletandem axle channel supportsGood dual tandem axle load equalization?MORRYDE 3000 TANDEM AXLE UPGRADETandem or single axle
