Lynnmor's avatar
Lynnmor
Explorer II
Mar 28, 2014
Tank Monitor Idea
We all know that the common tank level indicators are totally unreliable. Some higher end class A's have a way to adjust the tank level readings. See this youtube video for information: Adjust
There are some electronics guru's here that might chime in and give some input as to what components would be needed to build a simple trim panel for our cheap systems. It seems to me that if a small amount of resistance were added to a sensor line, to compensate for the increased conductivity of dirty tank walls, the readings could be corrected.
  • Way too much time involved in worrying about tank sensors.
    Are you going to constantly 'adjust' resistance based on how clean/dirty probes are?
    And how are you going to measure the amount of clean/dirty?
    Toilet 'burps' time to dump black tank
    Sink/shower starts to drain slower than usual..time to dump grey tank
    On-board pump goes burrrrrrrr and no water from faucet....should have added more water to fresh water tank when dumping holding tanks
    RVng is about FUN!
    :B:B
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
