- aguablancoExplorerDING, ding, ding.........we have a correct answer. Unless one is willing to invest in exterior sensors, such as See Level, this is the best option.
RichH2oldman wrote:
I have a feeling anything that would make your sensors work would be something you'd have to do on a consistent basis. Spend enough time in your coach and you won't need them. You'll get a pretty good idea of how long you can go. - 2oldmanExplorer III have a feeling anything that would make your sensors work would be something you'd have to do on a consistent basis. Spend enough time in your coach and you won't need them. You'll get a pretty good idea of how long you can go.
- IAMICHABODExplorer II
3 tons wrote:
Dump a large bag of ice cubes into the tank and drive stop and go for a few miles…
3 tons
And the Myth Continues :S - 3_tonsExplorer IIIDump a large bag of ice cubes into the tank and drive stop and go for a few miles…
3 tons - morphriderExplorerMake darn sure your black tank really is empty, look down the toilet to confirm. We bought a used 2018 model and I thought the sensors had issues as I drained the lines myself and nothing more was coming out. First long outing we were full the following day, verified by looking down the hatch, lol. There was the pyramid left behind from purchasing, an issue we had to deal with ASAP. Bags of ice on the way home thankfully loosened enough to drain correctly, then using the factory rinse technique we got it cleaned fully and gauges now work as they should.
- way2rollNavigator IIInstall a good tank flush if you don't already have one.
- TelemanExplorer
madjack60 wrote:
I use a toss in packet called commando from Amazon or Walmart. Last day of camping I toss one in and add water to the tank to get it close to full , then drive home. When I dump the tanks the following day the sensors are nice and clean
Thanks I'll try this. Looking at the product description it only mentions black water. Do you use it in the Grey water tank too? - madjack60ExplorerI use a toss in packet called commando from Amazon or Walmart. Last day of camping I toss one in and add water to the tank to get it close to full , then drive home. When I dump the tanks the following day the sensors are nice and clean
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
