RVhiker's avatar
RVhiker
Tank Washer
The black tank washer has worked well since new (2011). Today it would not; it seemed like no water went into the tank when I connected a hose to it and turned on the water. I could see the hose pressure up, but there was no sound of the tank spray head running nor any sound of running water at all. I turned off the spigot, and the hose had quite a bit of pressure when I disconnected it from the tank washer, so I do not think that there is a leak in the tank washer line. The hose input has always been closed with a plastic plug and there is a screen that is part of the washer so it does not seem like the tank washer plumbing could have been plugged with dirt somehow.
The only cause I can think of is a faulty vacuum breaker. Agree or other thoughts?
  • Blocked back flow preventer. Look to see if it is part of the sprayer or separate unit.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
