Roadpilot
Jul 05, 2017Explorer
I had a 7KW 240 VAC unit in a caoch house. It didn't raise the water temp enough for showers on a cold winter day in Florida. Replaced it with a 15KW unit that works great.
There is no way a 120 VAC unit could function even using all 30 amps from a pedestal. That's assuming the raw water is warm.
If the RV is 50 amp you could get a 240 VAC unit that uses two 40 amp breakers and actually uses approx. 30 amps. But that wouldn't leave much left over.
I know the make propane tankless hot water heaters. That may work better, but I know nothing about them.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
