- old_guyExplorerI have to ask you guys, in what direction do you wind on the tape. clock wise or counter
- nomad297ExplorerThe yellow tape has more tensile strength, doesn't shread as easily as the white and it seals smaller imperfections in pipe threads than the white. I could use white tape on a joint and have it not leak at 300psi with water, but the same joint might leak with only 50psi of air/gas.
Bruce - TerryallanExplorer IILooked it up.
White- single density, should only be used on NPT threads up to 3/8 inch in diameter.
•Yellow – double density, often labeled as “gas tape”
•Red of Pink – triple density, required on all joints 1/2? or larger.
•Green – oil Free PTFE tape, required for use on all lines carrying oxygen (i.e. – medical oxygen or welding oxygen lines). - Bull_RiderExplorerThe yellow tape is thicker.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
