Tour1
Jun 04, 2017Explorer
It's a 2013 with the canbus module system. It doesn't have the factory 7-pin setup. I bought the adapter to connect the P3 to the standard harness. I also have the 4-pin flat connector (installed & functional) to 7 pin connector, with a 2-wire cable heading up front for power & brake. Other than the red wire (vio/wht on the Ford side) everything is like a you-tube I watched.
Except a minute of you-tube done takes me an hour to do, longer if I have to add more parts.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
