tpi wrote:
Mine is PD 4645. With Wizard.  But as far as I can tell, Wizard just resets the charging sequence- you can't just skip to 13.2 volts and it will stick..I will test...
Need to press and HOLD to change modes.
4600 operation guide, p5WIZARD MODE BUTTON - The manual button has been provided to allow the operator to temporarily override the converter (not recommended) or to verify the converter is operating properly. For manual operation, Press and Hold the button. The indicator light will soon remain “ON” indicating Boost Mode. Continue to hold the button and the light will blink rapidly indicating the converter is in the Normal Mode. Continue to hold the button until the light blinks slowly indicating the converter is now in the Storage Mode. After the manual button is released the converter will stay in the selected mode. When the battery charge status changes, the converter will return to the automatic mode of operation to prevent damage to the battery.
