Muddydogs's avatar
Muddydogs
Temp sensor on solar controller.
The temp sensor on my Windy Nation P30L solar charge controller isn't working. Worked last fall when I unhooked the battery's for winter storage but when I hooked everything back up there's no readout for the temp. The wire I can see looks good and the connections at both ends look just fine.
I don't know how the temp sensor works, can someone explain how a wire hooked to the negative battery post tells the controller what the temp is? Also can I go to cutting the terminal end off the wire and put on another one or if my wire is cut can I fix the cut with a butt connector?
I'm thinking that if I have to pull the wire to see if its cut or not I will need to remove the battery ring terminal as its not going fit through the area its run in anymore.
  • afaik the sensor is a calibrated resistor that changes with temperature.
    The wire is generic so cutting and splicing to repair a bad spot should not change anything. Or just get a new one.
  • I'm pretty sure that it is a temperature transducer that, inside the terminal itself, has something like a bimetallic strip going to two wires that will be measured electrically by the controller. Higher temperature, lower voltage sent to the battery, something like that. You could just drop the terminal in the bottom of the battery box and it will measure the ambient temperature of the box the batteries are housed in. Or, it would even work if you taped it to the side of the battery case.
    I like using them on solar controllers, since the battery doesn't get overcharged in the hot weather, and gets a bigger boost in winter. Actually, the Battery Tender has an ambient temperature compensation, so I use one during storage time of the batteries.
  • Have you tried contacting the manufacturer? That would be my first move...
