MEXICOWANDERER
Sep 10, 2014Explorer
It's like the hyperbole that circulates about Mexico BFL. Give some of these squirrels a toe hold and they'll be on the roof in no time.
There isn't supposed to be -any- Delta T (difference in temperature between plates and electrolyte) in a cyclable battery. Period.
Starting batteries incur much greater Delta T due to wattage when discharging for starting an engine.
Adhesive mounting (like with Arctic Silver) a thermistor onto the negative battery post then sealing with gel coat is about as true an idea of what is going on, inside the battery as a person needs to know.
The same kind of malarkey goes on with vitamins and supplements. When the consumer claims....."it didn't work!" grab a roll of toilet paper...
It gets old BFL. trust me, it gets real, real old...
- Did you buy the powder or liquid? whatever you got was wrong
- So then you buy everything off the shelf and try it
- Was it cold pressued? Ooooo not cold pressed? wotta shame
- Brown? You gotta be kidding me. Only the white, works
- Sulfate? Who fed you that one, only the tartarate works, sulfate is a scam
- Poopsimomium Flatulancia only works if it is picked on a full moon
- Be sure it actually comes from Grokaminako province Madagascar
- Oh my god you kept it in the refrigerator that destroys it
- Has to be resealed within 93 seconds of opening or it goes flat
