ken_white
Sep 11, 2014Explorer
JiminDenver wrote:
How far apart will the internal, external and ambient temperatures be?
Depends on whether the battery bank is heavily loaded, or in a bulk charge state vs. lightly loaded and float.
JiminDenver wrote:
How does the controller use the info? Does it one voltage for 21 degrees and another for 22 or is it a range and you don't see a difference between 20 and 25 degrees and at 19 degrees it will change?
The controller adjust the charge voltage with a negative slope (Delta Voltage)/(Delta Temperature). The slope magnitude is a function of battery chemistry.
JiminDenver wrote:
Last question is how important is it to have TC for a rig in storage with fully charged batteries vs those in use?
Depends on many factors, but in general lightly loaded batteries rarely see any significant increase in electrolyte temperature but may not get fully charged at real low temperatures.
