BFL13
Sep 12, 2014Explorer II
Mark, good post on the various aspects.
I still have my copy of your table from when we were looking at setting voltages for my 100a PowerMax variable voltage charger in cold temps a while ago.
At the time (was near freezing out) I was using 15.2 for 14.8 nominal and you pointed out that the battery might be warmer than ambient from being charged at 100a, so my voltage setting was probably too high.
I have no way to measure internal battery temp so it is a guessing game in a way. My answer is to use the table but back off the compensation a little.
If I am using the VEC1093DBD (it has temp comp) at the same time as the 100amper I can see on its readout what the VEC is using for voltage and use the same for the 100amper. I don't know the co-efficient for the VEC but I take it on faith that it is "about right."
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
