hammick
Apr 09, 2015Explorer
Temperature compensation conversion ?
I'm not smart enough to figure this out.
My Interstate GC2 battery specs base temp compensation on 10 degrees Fahrenheit above or below 80 degrees F.
My Blue Sky charge controller bases it on one degree Celsius above or below 25 degrees C.
Below are the Interstate specs and default setting of my controller. Looking for advice on whether I should leave the controller at default setting or convert to interstate specs and if so what is the conversion? I am installing the Blue Sky temp sensor. Thanks.
Interstate specs
Notes: 1. All charging voltages shown above are for 80 degrees F. For every 10 degrees above 80 F reduce voltage by 0.028 VPC. For every 10 degrees below 80 F increase the voltage by 0.028 VPC.
Blue Sky specs
Default setting: (–5.00mV/°C/cell)
setting range: 000 – 800 (–0.00 to –8.00 mV/°C/cell)
setting steps: 10 (0.10mV/°C/cell)
description: Battery temperature compensation factor (decimal point missing in display such that 500 = –5.00mV/°C/cell
Default provides overall factor of –30mV/°C for 6 cell 12V battery)
Interstate specs
Blue Sky specs
