Gjac
Apr 29, 2022Explorer III
Do you have one wire or two wires going to the sensor? If one, the ground is through the treads to the block and could be bad. I would remove and check threads clean and reinsert. If two, one is a ground wire, check it to a known ground. The other wire should have voltage to it, voltage will vary as sensor get hotter. Turn key on to see if voltage is there. If you have voltage on one and ground on the other your sensor or gage is bad if you are missing ground or voltage one of your wires is bad.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
