Gjac
May 01, 2022Explorer III
groundhogy wrote:Yes one wire is positive and has volts which you measured, the other should be the ground wire. Set your meter to ohms and measure from the terminal to the engine block and see what you get, if anything.
I didn’t try measuring that since it is a 2 wire situation.
Ground matters in this situation?
