Gjac
May 03, 2022Explorer III
groundhogy wrote:If you set your meter to ohms and touch the positive and negative lead together what do you read? This is what you should read when you touch the terminal end to the engine block to check ground. Your meter may be off some that is why I say it should be the same.
So the one has 5vdc.
THe other is ground and measures about 10 ohms from it to something on the block.
When I ground and open the +5v line the gauge reads zero hot to pegged hot (grounded).
