TomG2's avatar
TomG2
Temporary Glue
My suction cup GPS mount will not hold to the dash mounted base for very long lately. What I am looking for would be to glue the mount to the base, but be removable when desired. I thought about Velcro, but not sure if that is what I want. Yes, I have cleaned the mount and suction cup thoroughly.
  • Try a little dab of cooking oil. Just a light sheen. Mine holds for days after that.
  • I don't know what GPS you have, but a replacement suction cup mount is cheap. Garmin for example.
    IAMICHABOD wrote:
    Having grown tired of the suction cup failures I went with a Mirror Mount
    Works great and stays where I want it and the GPS is easily removable.
    That is very cool! And not expensive either. I like that it can be mounted above the mirror so as not to block your view, and still be legal in all 50 states.
    produces a heck of a large blind spot.
    bumpy
  • Having grown tired of the suction cup failures I went with a Mirror Mount
  • Go to a glass shop and have them cut you a circle that will fit the dash piece. Glue it in place. Spit and stick the GPS mount. Done and the GPS is not glued and easily removable.
  • I have tried all the usual stuff like spit and polish. The dash mounted piece appears to have a slight warp to it. There is no really flat spot and I already have the base glued down. I am thinking that maybe a thermoplastic glue of some kind might work.
  • Spit on the cup and rub it around. It will stay put a lot longer.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
