Salvo
Dec 02, 2014Explorer
You have a reading comprehension problem. I said the resistance between the lug edge and the stud is orders of magnitude greater than the resistance between the compressed stack of lugs. So yes, some fraction of current will flow from stud to lug.
When you consider the stud has V-shaped threads, there's very little contact between the stud and a small part of the inside edge of the lug.
You're making a mountain out of a molehill.
OnaQuest wrote:Salvo wrote:
Who pushed your button? There's a good chance the wire lugs make no contact with the stud. Current flows through the stack of lugs. The resistance between lug and stud is orders of magnitude greater than the resistance between lugs. There is no compressive force between lug and stud, that's why this resistance is high.OnaQuest wrote:
I don't need to read it again. I agree, the stud in the first case IS NOT DESIGNED to carry the current, but if you think there is no current flow through the stud, especially if there is any resistance in that tall stack of terminals, you're wrong.
No one ever said, or even implied, that the edge of any terminal against the stud was a reliable current path. Some of you folks are just too narrow minded to consider the facts. Current can very easily pass (and would probably be impossible to stop) through the terminal contact with the nut, through the tightened threads, and on down the stud.
This is a fact, and is expected and depended upon in many grounding lug situations for otherwise insulated chassis configurations. Accept it, and get over yourself.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
