buylow12's avatar
buylow12
Test and Adjust Water Pump Bypass Valve with Unit Removed
Ok, I am replacing my current pump because it is apparently allowing water to flow back into the tank causing it to cycle and there is no longer rebuild kits sold. The replacement I bought is the Shurflo 4048.
Yesterday I had someone come out and install it(The pump is in a really difficult place to get to). It pumped water great but never shut off. He pulled, tested it, and claimed it defective. So he then put my old pump back in until I got another replacement. So today I call shurflo to go about returning it and they recommend adjusting the bypass up. I just tried to call the tech to see if he tried that when "testing" but haven't heard back yet. However, my guess is no.
If it was still installed all it would take is a quick turn on a hex screw to test it out. However, since it's been removed I need to setup some kind of rig to get water and power to it. I'm think I'll need a bucket with some water in it, a hose for the inlet side, another hose with a shutoff valve for the outlet, and someway of getting power to it. I figure some alligator clips and then I guess I'll need some wire, and I have some of those twist on splice deals that I can use to join all that together. Then i assume it would just be a matter of running some water through it, then shutting the valve on the outlet side, and the adjusting the bypass up to see if it shuts off.
Am I forgetting anything? Any tips? Anyone have any idea how much one turn adjusts the pressure up? I'm going to have to go and buy all this stuff but since my old pump still moves water I was going to set it up to pump water from an external tank into the onboard tanks and I'd need all the same stuff anyways I think. It's gotta be worth a shot because if that's the problem I fully expect the tech to eat the cost to put it back in, along with the cost to put the old pump back in.
Thanks for the help,
Tim Czarkowski
TotalTravelers.com
  • Well I ended up testing the pump and indeed it was just fine, it just needed a quarter turn on on the pressure switch screw which happens to be right on the face of the pump.
    On a related note I just want to warn everyone about A Mobile RV Repair in Tucson, Arizona. I had some truly bad service, followed up by some incompetence, a bit of No Call No Show, finished with a dash of refusing to fix the issue. It was so bad I wrote a whole blog post about it, lol. Check it out here http://totaltravelers.com/2015/11/22/a-mobile-rv-repair-tucson-az-the-worst-service-of-a-lifetime/
    In short he told me the pump was bad, it was not. So I was charged to put the new pump in, take it out, put the old pump back in, and then he expected me to pay to put it back in when there was nothing wrong with it in the first place? He has sense then refused to fix his mistake and has been very rude and professional all the way through.
    Tim Czarkowski
    TotalTravelers.com
    P.S. That sounds like a great fix, wish I thought of that earlier...
  • Your ideas will work OK but it would be a lot simpler and cheaper to just stick a check valve on the original pump output line. Google " Shurflo check valve "
    Art.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
