MEXICOWANDERER's avatar
Jun 28, 2017
Test Light "Look Ma! No Ground Clip!
General Technologies Corp
GTC CT8002 Cordless Circuit Tester
4.6 out of 5 stars 53 customer reviews
| 3 answered questions
Price: $18.78 Free Shipping for Prime Members
In Stock.
Want it tomorrow, June 29? Order within 3 hrs 14 mins and choose One-Day Shipping at checkout. Details
Ships from and sold by Amazon.com.
Professional cordless computer safe circuit tester constructed in rugged stainless steel requires no ground wire or clip and a safety V-groove accessory is provided for piercing and carrying
Negligible current draw ( 20 micro-amps) is 10,000 times less than regular lamp type testers and is completely safe when working around sensitive electronic control modules and sensors
Operates between 3 and 28 Volt DC in battery powered systems and has a light and sound indicator to give an audio and visual signal when positive voltage is detected
Solid state high impedance electronic circuitry
Long-life alkaline batteries installed
  • 4x4van's avatar
    4x4van
    Explorer III
    Again, this (the original post) is NOT an AC tester, nor is it a proximity tester. It is a 12vdc tester that utilizes your body as a ground path rather than a wire with an alligator clip. The V trough is simply an added piece to easily center the wire so that the metal tip can more easily pierce the insulation; it can be removed.
  • It's the lack of a ground clip that appeals to me. Proximity sensors are damned near useless when digging in a bundle of wires :)
  • I have heard of DC voltage proximity sensors.
    I even ordered one on eBay, which didn't work. A DC voltage on a wire would cause an electric field near the wire but it would be hard to detect in comparison to the Earth's E field and I expect it would be expensive.
  • The Class VI high voltage alert I had to wear was a four thousand dollar item for 218 Kv AC work. 4-meter corona on those systems.
    Plug DC puncture hole with silicone dielectric grease when finished.
  • Thanks for the tip on the DC tester with the clip pin contact, Mexico Wanderer. I like it but don't need it often enough to justify the $30 Canadian cost. I'll stick with using a needle by hand. Hmm, maybe I could make one of those needle clips with a closepin and needle.
    Also thanks for the grease tip for the hole.
  • Ah yes, the Canadian Peso. Failed Lawyers and Greedy Bankers. Say, that sounds similar to the way of greed south of Ottawa. Never let "the burglar" explain your rights as "The Victim". It's almost as degrading as paying a banker to float your bank balance.
    I used an ironwood V-block. One inch square. Handle telescope off an old magnet parts retriever
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
