HiTech wrote:
I was with you up to this point. Help me out with where that MPP voltage comes from?
Jim
Jim
You are absoulute correct. I was just picking a typical Vmpp for a typical 12volt panel to do an estimate of max amps provided. Your correct in that Vmpp is panel specific. I was just estimating the difference in amps provide via PWM and MPPT assumming I could drive the solar panels at max capability under both setups.
Getting the actual data results will be interesting to see how close those estimates are and how close the claims from MPPT manufacturers are in some simulated real world conditions
