It's not for sure I will get to run this test, but at least I'll be ready thanks to you guys providing these tips.
I will have to note what the MPPT controller does in the way of being PWM at times so I test it when it is doing MPPT.
I already have the results for PWM side of the test I suppose, but I will run both anyway if I have to change any wiring from the way it is now that might throw off the numbers wrt voltage drops somehow.
All I will do for the 12v test is leave my array as is and swap controllers in place and see what the amps are now. Ought to be easy.
I will then redo my two panels into series so it is a 24v 200w "panel" and see if the MPPT amps are any different from what they were on the 12v test.
Where it gets sticky is all this stuff about voltage levels. My morning voltage these days is usually 12.6ish and soon gets into the 13s. It has no value for me to know what the comparable amps would be at 12v. I would just like to know what diff it would make if I had MPPT instead of PWM in my "operating range" (say 12.6 to 14.6v)
If I can, I will try for a test of each kind (12 and 24) around 13 and another around 14.3ish.
The two panels are not quite the same in real life when I take Voc and Isc and Sun says there is a small tolerance in their specs, so if that screws up the MPPT --too bad! :)
I often get say 20.3 Voc (temp effect AFAIK down from 21.x) but 6.4 Isc on one and 6.2 on the other, and it comes out at 6.3 av using both together at 12.6a. that compares well with my 130w Sharp panel at 8.2 Isc. 100/130 x 8.2 = 6.31
In series to do the 24v test, it will come out however the lower panel does I suppose, can't be helped. The amps I get will tell the tale.
