jlscjs
May 07, 2015Explorer
westend wrote:
Remove the leads (wires and connectors) from the water heater element and measure ohms across the two connections on the element. Infinite resistance would mean the element has an open and is not good. Zero ohms would mean the element is shorted and is also bad. I don't know the correct range of resistance for a 120V water heater element but it may be 9-10 ohms.
Thanks, what would the ohms reading be if the unit is working or is that possible to tell
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
