How can I test a convert without pulling it? Thinking disconnect house battery while plugged into shore power and using a multimeter on the + & - but AC or DC what to set the meter on.
You can easily check output by measuring voltage across the battery terminals when the converter is powered. The voltage should be > 13 V. Meter is set to DCV.
