How can I test a convert without pulling it? Thinking disconnect house battery while plugged into shore power and using a multimeter on the + & - but AC or DC what to set the meter on.
Another easy test to see if the converter is working. Do this with the battery charger removed. Measure the battery voltage. Turn off the circuit breaker feeding the converter. If the voltage falls the converter is putting out something. If the voltage doesn't change then it is not working.
Said differently, when the converter is turned on it WILL cause the voltage to rise by a noticeable amount if it is working.
