JAXFLExplorerNov 14, 2015Testing a converter?How can I test a convert without pulling it? Thinking disconnect house battery while plugged into shore power and using a multimeter on the + & - but AC or DC what to set the meter on.
MrWizardModeratorNov 14, 2015Turn off power to the converter, before crawling in there, if the fuses are bad you want to replace both, come out and then turn power back on
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 24, 2026
Related ContentHow to test Converter voltageFirst mileage test result.No 12 Volt without converterHow to test rv converter?80 amp converter and eu2000i
