Hi 2old,
I've been using "new to me" surplus acid telcom jars for 10 months. I'm ecstatic with them. They recharge fast to a much higher percentage before they start to taper the charging rate. They will accept 27 amps each when hungry so I have deliberately throttle back my charging rate to keep to that limit of 108 amps for four jars.
I use them regularly with the Magnum hybrid inverter with the load support feature. This is especially useful when running the generator because I can run it in eco mode, saving quite a bit of fuel when I'm in the mountains.
I have seen the inverter draw 276 amps for short periods of time.
I still think that most battery banks for RV's are far too small (and I include mine in that category now at 566 amp-hours). If they ever get LI that works in the cold I'll be lining up to move over.
