When using the generator only for charging, not cooking etc
Like after supper
I Will generally stop at 2 amps per battery, 8 amps on the display
But when using the A/C I just let it charge even when down to 0.5 amps per battery
Often this is when I will kick on the recondition or desulfate mode of the B&D charger
Bay doors are open and usually parked in shade
There is no sign of bulging on my CD tech batteries
Yeah yeah better to do the controlled over charge in the cold weather
In cold weather I don't need to run the a/C and generator all day
Right now.. The amp meter is showing 1.6 amps at 13.39v ambient temp 88°f
This from a 70 amp PD with charge wizard
In this weather I do not kick it up to boost mode
