Gjac
Dec 24, 2013Explorer III
Old-Biscuit wrote:Is the Norcold recall fix measured at the same place as the ARP? If it is 300 degrees is a lot more heat? How many inches above the electric element is the temp sensor mounted?
What were freezer & food section temps?
What temp setting (1-5) was used?
Fairly repetitive ON/OFF cycle.......
And having a shut-off at 444*F is a heck of a lot better than the 750*F Norcold Bandaid Recall Fix.
Be interesting to have a fridge you could destroy by testing it in off level conditions to see the ON/OFF cycle and how much affect off level has on temp rise over time.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
