Salvo
Dec 24, 2013Explorer
I placed the temperature sensor about 3 inches above the curved tube that contains the ac heating cable.
What's the writing on the wall?
1. 750F is good enough to prevent fires.
2. 750F will probably cause fridge damage.
3. Replacing heating units is a good business for Norcold.
Sal
Sal
Gjac wrote:
Is the Norcold recall fix measured at the same place as the ARP? If it is 300 degrees is a lot more heat? How many inches above the electric element is the temp sensor mounted?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
