Gdetrailer
Dec 25, 2013Explorer III
Chris Bryant wrote:
One thing to keep in mind- the ARP is designed and calibrated to shut down before damage occurs- if you read the technical docs, it shuts down when the boiler temp is over what a properly operating unit would be- the only way the boiler temperature would be that high is if it is starved for ammonia. Keeping the unit from catching fire is just a side benefit :)
The OEMs really should have this installed from the factory- the technology integrated in to the control unit would be far superior to anything they have now.
It is my understanding that the designer/inventor of the ARP did approach Dometic and Norcold with this device but in BOTH cases was flatly turned down.
You see, if the CU is proactively monitored and cared for they (the fridge companies) would SELL LESS fridges and CUs as REPLACEMENTS.
This in turn would be reflected in their bottom line in reduced sales and profits. You bet they are making a killing in aftermarket sales by allowing a higher off level spec and higher boiler temps...
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
