Salvo's avatar
Salvo
Testing ARPrvSafe and Fridge operation
I installed the ARP controller in my MH. The install instructions were straight forward and easy to follow. It takes a good 2 hours to install.
Here's what you get.
The controller is mounted just below the fridge.
The temperature sensor is mounted on the heating tube above the AC heating element.
The ARP controller opens up a relay that cuts power to the Norcold controller.
I ordered the controller that has the data streaming connector. I can now store temperature data on a laptop. That will be a big benefit in understanding operation of the fridge under various conditions.
Here's the turn-on plot. It takes less than 25 min to get to operation temperature of 360 degF.
The first on-off-on cycle. There's a little overshoot.
Multiple cycles and turn-off
The fridge may not be in equilibrium yet. The first few cycles have about 22 min ON time and 25 min OFF time. No food was in the fridge for this test.
The ARP controller shuts the fridge down when the temperature rises above 444 deg.F.
Sal
  • What were freezer & food section temps?
    What temp setting (1-5) was used?
    Fairly repetitive ON/OFF cycle.......
    And having a shut-off at 444*F is a heck of a lot better than the 750*F Norcold Bandaid Recall Fix.
    Be interesting to have a fridge you could destroy by testing it in off level conditions to see the ON/OFF cycle and how much affect off level has on temp rise over time.
  • Hi Salvo,
    As always, informative. Thanks for posting these results.
    Did you happen to note the ambient temperature?
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 02, 2025
