westend wrote:
The camera may have failed but you can check the connecting cable with your multimeter to see if power is present at the camera connection. You will need to sort out which position is (+)--power and which is (-)-- ground.
This is where I am having trouble understanding the checkout procedure. The cable coming out of the MH connects to the camera with a 4 pin connector. When I unplug this connection, the cable from the MH has four FEMALE holes in it. Will the probes on my multimeter fit into these holes without damaging them? If so, do I just plug in the probes into different holes until I get a reading? Thanks.
