RCMAN46
Nov 06, 2017Explorer
I have found that most 4 wheel brakes draw about 1 amp per volt applied.
If you can measure the battery voltage at the same time you measure the current you should be near 1 amp per volt.
If you are not within 2 amps out of the expected 12 amps at 12 volts then you should check each wheel to find where the problem is.
