time2roll
Nov 07, 2017Nomad
Snowman9000 wrote:Trouble with a multimeter is you need to be in series with the circuit. OK to test the 12 amp draw with a 20 amp rated meter.
Prodigy P3 controller, not giving any errors. I could get some slowing from the trailer brakes when I pulled the manual lever, but nowhere near enough. This was after brake adjustments.
I suspect poor wire connections, but don’t want to break them open without testing what I can.
Extra work to go wheel to wheel to find the culprit. Clamp-on meter will identify the issue without cut and repair.
When I had drums I did find it took a few stops before full braking power was obtained. OK maybe 10 to 20 stops. So get on some open road for a bit before you call them bad.
BTW P3 works great with disk brakes :)
