BFL13
Aug 22, 2018Explorer II
"At 7AM this morning, we've got a little marine overcast today, I was getting 14v from the PV array (max at 40v). The battery was down to 12.6 after sitting all night. I'm sure the system will be hitting the batteries with 14.6 within the next hour or two"
I assume you meant amps instead of volts.
It makes a difference how to answer your question whether that 40 amp controller is MPPT or PWM. Your question is easy to answer either way but not both.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
