bpounds
Aug 22, 2018Nomad
BFL13 wrote:
You compared the 14 with the 40 and your controller is a 40 amper. So it was not volts! Morning battery voltage (no charging) would be 12.x, rising during the day to 14.x with solar charging.
No, I made a point of saying the PV were putting out 14V. Not the charge controller. I'm wired series/parallel, and the PV is usually at 38-39V once the sun is up. It was intended to make the point that the sun was not yet up.
That it happened to be 14 was just coincidence, as was the 40.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
