bpounds's avatar
bpounds
Nomad
Aug 21, 2018
Testing potential solar harvest?
Now that I have a solar installation up and running, and it's working great BTW, I feel a little under informed at times. For example, at any given point in time, what is my array capable of harvesting with current sunload? All I can see is what my batteries will accept at their SOC at that moment.
Is there an easy way to put a load on the controller? To somehow make it "gimme all you've got Scotty". With batteries disconnected obviously. Or do we just assume our array can do XYZ based on panel specs?
I feel like I won't ever see what the system can actually do, without discharging the batteries way down and then hitting the solar switch, and even then it is only a short term metric.
  • Careful unhooking all your batteries without disabling the solar panels first...blanket, darkness etc.
  • Hi,
    If you have an inverter load it up and that will soon have the solar pumping out watts.
  • RoyB's avatar
    RoyB
    Explorer II
    I pretty much know what to expect with charging my battery bank using the on-board Converter/Charger setup.
    In my case I want to get charged up to point that I can use my batteries again right away so I follow the 50% to 90% charging rules so I can get safe use of the batteries in as short of charging time as I can pull off...
    Again in my case I know how many DC Amps I can pull from my battery bank so that I can stay with-in the 50% charge state. When I see 12.0VDC on my battery monitor I know I am approximately at the 50% charge state so I will stop using my batteries until I get them charged back up to the 90% charge state as soon as possible... If I can supply 17-20Amp per 12VDC battery in my battery bank I know they can be charged from the 50% charge rate to the 90% charge rate in approximately a three hour charge period. When camping OFF-GRID I will run my 2KW Honda Generator with the Popup Trailer shore power cable connected to do this. Most often the camp sites allows the use of generator starting at 8AM each morning so this is the perfect time for me to do this...
    I also know from experience my battery bank will accept around 53 AMPS DC Current when first hit with 14.4VDC charge from my smart mode charger setup when the battery bank is at its 50% charge state. This will last for around 20 minutes and then starts tapering back. After around one hour of charging with 14.4VDC from my smart mode charger it will then drop back to 13.6VDC.
    At this point I would like to shut down my generator and hook up enough solar panels to continue my charge mode the rest of the afternoon in high sun. I can get my battery bank up to its 90% charge state by running the generator for an additional two hours after it drops down to 13.6VDC. Hopefully in the several hours of high sun left I can do this setup using only the solar panels.
    I would most likely want to have at least 20AMPS of DC Power being generated by the solar panels to feed my three 12VDC batteries... A single 120WATT Solar panel will only generate around 6AMPS DC current to give you an idea how many panels you will need...
    These are my thinking of using solar panels to charge my battery bank for me when we are camping OFF-GRID...
    We may be using more power then most do when camping off grid because of my Ham Radio use and wife's use of watching HDTV … I regularly see 20-25AMPS of Dc Current being drawn from my battery back between the 6PM to 11PM time frame each evening to give you and idea of how much we pulling from the battery bank each evening...
    It all kinda depends on each camper's need for power I guess...
    I know I can do it by running my 2KW Generator for three hours each day to get my battery bank from its 50% charge state to its 90% charge state. Would like to reduce the generator run down to around one hour aday and let the high SUN get my batteries back up to their 90% charge state so I can do all of this all over again each evening...
    My 12VDC battery bank story haha... I'm sure other do it differently...
    Roy Ken
  • You live off batteries so the # of them and the size will determine what your drain rate capabilities are(how fast your panels replenish the battery bank). A moderately sized system should include 4 6V deep cycle batteries for maximum capture of charge during the day. Very generalized but fairly applicable for the frequent boondocker.
  • keep the controller in bulk mode with a load or multiple loads.
    1/2 a day is enough cuz the 2nd half of day mimics the first half.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
