path1
Jul 26, 2014Explorer
dougrainer wrote:path1 wrote:
OP here... Guess what I learned today???
My lighter is butane and it did work good for testing alarm.
I thought those "Bic" type lighters were filled with lighter fluid!
I learn something new everyday.
See my previous post. Butane WILL work to test but the LP detector makers tell us to NOT use Butane based lighters to test a LP detector. Something about causing problems with the sensor's. Doug
Doug what post??? I would like to read it. http://www.rv.net/forum/index.cfm/fuseaction/search/parms/sw%7Bbutane%7D%7Ckm%7Bexact%7D%7Ckl%7Bm%7D%7Cfm%7B%7D%7Cpd%7B365%7D%7Cma%7Bdougrainer%7D/sr/1.cfm Don't see the one you mention.
(Edit part)Doug Never mind...found it.
DO NOT USE A CIGARETTE LIGHTER TO TEST THE CO /
PROPANE GAS ALARM. Butane gas may damage the sensors.
DO NOT attempt to test the alarm by any other means than by using the
TEST/RESET button. DO NOT attempt to produce CO - to test the alarm.
The TEST/RESET button tests all functions of the alarm and is the ONLY
safe way to be sure the alarm is working properly.
The alarm may be tested at any time -The TEST/Mute switch is located on the front of the alarm Press and hold the test button for 1 second. The alarm is working properly if the GREEN indicator light changes color to RED and.......................
Thanks for pointing that out.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
