dngaul's avatar
dngaul
Testing Shows all Outlets have "Bad Ground"
I discovered that all the outlets in my RV test to have a "bad ground". Since the outlets involve multiple circuits, I assume that the problem is associated with the main ground. The shore power outlet is ok and the ground on the main bus is solid and clean. All of the outlets still function. What are the possibilities?
My RV is a 2002 Pace Arrow 37A with 30 amp service.
  • RoyB's avatar
    RoyB
    Explorer II
    larry cad wrote:
    Keep in mind, the breaker panel in your RV is considered a "sub panel" for NEC purposes. That means the ground and the neutral are not connected together at the RV, nor at the campground power pole. The neutral to ground connection is only made at the campground main breaker panel.
    In addition to this my WFCO WF-8900 Power Distribution Center has a NEUTRAL BUS BAR connection to all NEUTRAL connections and passes this on to the NEUTRAL lead of the shore power cable. This NEUTRAL BUS BAR is isolated from the trailer FRAME ground.
    I also have a second GROUND BUS BAR where all of the GROUND CONNECTION from the ROMEX cable feeding everything is tied to and this is passed on to the GROUND wire of the Shore Power Cable. The difference here is the BUS BAR also goes directly to the WF-8900 Chassis Gnd connection which is also going to the trailer frame ground with a solid wire...
    You can see this here on this WF-8700 main frame drawing...
    This is how the GREEN wire coming from the Shore Power cable goes to the trailer skin frame ground on my trailer...
    Roy Ken
  • Pull the plug around inside and check continuity from the pin to the bus.
  • How long since you opened the RV breaker box and tightened all the screws holding wires? A rolling earthquake vibrates wire connections loose quite often. I check mine every year and usually find at least one that tightens a bit.
    OF COURSE, DISCONNECT FROM ALL 120VAC POWER FIRST!
  • What kind of test are you performing that shows a "bad ground"? Are you using a test plug with neon lights? Are you plugged into a shore power plug when you make the test? If so, then maybe the ground connection in the campground power system is bad. Need to know more information.
