cannesdo
Feb 17, 2016Explorer
opnspaces wrote:
For a quick down and dirty test if the drum is off. Have someone hold something metal near the magnet and then go slide the manual lever on the brake controller all the way over. The metal piece should stick to the magnet. If it sticks good and tight you have brakes. It it won't stick then you have a problem. You have to use the manual lever on the brake controller since some will not activate from the brake pedal unless the vehicle is in motion.
For the other wheels that still have tires on them, jack that wheel up and have someone spin it while you apply the manual lever on the brake controller.
Ah...others have warned me about working with the drum off. That's good news. I've done every test but that one. I started this quest to test everything because nothing stuck to the magnets, then I learned the brake needs to be engaged for that to work, then I got distracted by other tests...endless videos...I'll do the magnet and spin tests in the morning.
Thanks so much...
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
