Chris_Bryant
Oct 31, 2014Explorer II
Here you go, that should give an idea. It is best to tension rolled up, with the arm zip tied against a block- just a little extended. It's 8 turns rolled up. You can tension, then put a cotter pin in to hold it.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
