NinerBikes
Oct 31, 2014Explorer
Chris Bryant wrote:
Here you go, that should give an idea. It is best to tension rolled up, with the arm zip tied against a block- just a little extended. It's 8 turns rolled up. You can tension, then put a cotter pin in to hold it.
Thank you so much for that link!
I don't know why Dometic doesn't include the instructions in the box with a new arm?
Yikes, thats some serious preload, I need to get more on there, only got three. Is there some sort of spanner wrench to pretension?
Edit: found the answer, need to get some special crank handle, and apply clockwise, 8 full turns, then pin it in place with a cotter pin. Where to rent or borrow that crank handle?
Really wish that Dometic included instructions to pin the unit with a cotter pin before removal to R&R a bent unit, to prevent the loss of preload. Another WTF moment. Oh well, live and learn. Hard to RTFM when one was not included printed out in the box.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
