Anyone done the "The Big 3" (charging wire) upgrade to their TV's/MH's? https://www.youtube.com/watch?v=gnmXKjm3tZE Like it or not, disadvantages? How did it play the ECU when the charging wi...
Any alternator, no matter the control, just attempts to maintain voltage at the output. Where the power goes the alternator does not know or care. Jumper cables are fine but will be expensive and bulky if the wire is thick enough (#2)to minimize voltage drop. Although consider a 1000 watt inverter to power a 20 amp battery charger to get the right voltage right on the RV trailer battery. Low cost MSW inverter should be fine. The upgrade in the video is not going to help.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
