pickjare
Jun 08, 2016Explorer
It's likely a connection then if the battery is in fact good, especially if it was still charged when lights didn't work. On my trailer the battery cables go inside to a PDC, a power distribution center--the place where all fuses are.
I would connect battery, check for poWeR there at PDC. Check for ground at PDC. If ok, and try loosening and retightening those two power and ground cable bolts, next go to converter connections. Same thing, loosen then retighten check VoLTs at each point along the way.
Even better to do all this with lights on drawing a load you may see them flicker as your working and know problem is in that area. Things get bumped around, maybe something loosened up.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 20, 2026
