MEXICOWANDERER's avatar
Feb 10, 2018
The Golden Age Of Tool Instruction Printed In China...
Some assembly required never made me smile.
Then there is this bit of wisdom using an electric drill to fasten pop rivets.
1.Small size and easy to carry, more efficient.
2.Lower noise.
3.A horde of rivets function, pull a good effect that it does not waste a rivet.
3.Can complete drilling, pulling rivets and screwing, as long as you have a drill.
4.Contrast with the traditional riveter:
1)Hand riveters is laborious and inefficient.
2)Traditional electric rivet gun is heavy, not portable, noisy and drop rivets. The internal structure is easily damaged.
Usage:
1.Hold the riveter body, drill reversed.
2.When you hear "da da da", the screws can be inserted into the nozzle.
Using the wrench to install the right size nozzle.
Using the wrong size will get stuck.
  • GordonThree wrote:
    Screws can be inserted into the nozzle...?
    Yes but, not until you hear "da da da", whatever that means.
  • In '89 and still to today Kubota diesel engines on portable Lincoln welders have a sticker by the block coolant drain that reads
    During cold weather drain coling water perfectly for preventing frozen.
    OK we got it, The entire maintenance manual reads like that.
Having RV issues? Connect with others who have been in your shoes.24,194 PostsLatest Activity: Jan 29, 2025
