dougrainer
Sep 27, 2019Nomad
SoundGuy wrote:dougrainer wrote:
The mechanical just has the 2 wires. All the Tstat does is connect(close) the 2 wires to make a circuit back to the furnace. So, just replace with another Mechanical. Digital units will require extra wiring you will not have at the existing tstat. Doug
Hate to disagree with you Doug but I installed a simple digital thermostat in my 2003 Yuma. It's self powered with an internal battery and all that connected to it were the 2 wires that were wired to the original bi-metal thermostat.
I also used that very same thermostat in our TrailCruiser hybrid.
In both those campers the thermostat controlled just the furnace but in our KZ Spree which had ducted A/C the thermo controlled both the furnace and the A/C but I used the same wires that were wired to the original thermostat.
I Know about battery powered. But, not really needed for a basic mechanical wall furnace tstat. As another posted, what happens when the battery goes dead? Doug
