MEXICOWANDERER's avatar
Apr 17, 2015
The New Generation Of 12-Volt DC Relays
http://www.ebay.com/itm/New-Solid-State-Relay-SSR-40-DD-DC-DC-40A-3-32VDC-Input-5-60VDC-Output-for-Y5RG-/371290954044?pt=LH_DefaultDomain_2&hash=item5672aa593c
http://www.ebay.com/itm/Aluminum-Heat-Sink-for-Solid-State-Relay-SSR-Small-Type-Heat-Dissipation-10A-40A-/200957657490?pt=LH_DefaultDomain_0&hash=item2eca028192
Inexpensive. Zero contacts to corrode or burn. Control voltage can be miniscule down to three volts. Can be fifty feet away from switch using 18-gauge wire. If mounted with care, sharing an equal load manifold wiring split I have paired these critters and shot 70-amps through them for weeks at a time. Voltage drop is in milliamps. But they must be fused. I recommend 35-amp fuses.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 16, 2026
